Quite like it JT, a little unbalanced. Top to the stem/foot.
definitely no, no, on the black bit. If you want black lines grind a 1.5 mm parting tool from an old screwdriver,
300mm of thin wire each end wound around couple of 75mm dowels and thats your burner. A few seconds held in the groove made by the parting tool, a well defined black line at virtually no cost.
John. B
