Gluing Rubber to Wood?
thetyreman
4 Mar 2016
earth
I have a rubber seal that I want to glue directly to a door rebate, any recommendations? should I use epoxy, double sided tape? hide glue? so many options.
I’ve used something like this in the past to glue rubber strips to the bottom of makita planer base
    99.9 KB
Starbond do a flexible super glue, I used it to fix the sole on one of my trainers, worked really well. I was initially sceptical as "normal " super glue would have definitely gone crispy and cracked off but this flexible stuff was great.
Ollie
I have always found that most glues will stick to wood but very few stick to rubber, glass, ceramics, metal, etc. So find a glue that sticks well to the non-cooperative one first and it’ll probably stick fine to the wood.
I don’t know how much you are doing but MB Fibreglass sell some excellent two part casting rubbers which I reckon would definitely do the job if contact adhesive won’t.
Good luck.
CT1, run a bead and wang on the seal. Mind you, you wont be able to get it off again if you need to.
