phil.p":6qe10z3i said:I must admit in fifty years of using all sorts of PVA I've never had a joint fail - so I find the fascination with spending much more than is needed (Titebond) a bit odd.
PVA is more than strong enough for a table leg but I wouldn't dream of using it for segmented lathe work due to creep.Jbtb":1jiqusv1 said:join different pieces of wood together prior to turning what is the best glue to use to form a solid block of wood .
woodpig":p1u2ingh said:That's the point though isn't it, the OP wants to:
PVA is more than strong enough for a table leg but I wouldn't dream of using it for segmented lathe work due to creep.Jbtb":p1u2ingh said:join different pieces of wood together prior to turning what is the best glue to use to form a solid block of wood .
Titebond 3 is better than ordinary PVA according to the tests but with even this I've seen a small amount of creep on turned work so next time I'll be using Cascamite. :wink:
phil.p":2cnf1aom said:I must admit in fifty years of using all sorts of PVA I've never had a joint fail - so I find the fascination with spending much more than is needed (Titebond) a bit odd.
http://www.toolstation.com/shop/p61864?searchstr=d4
andersonec":3ensw16c said:When the word "creep" is used when gluing up segmented wood turning is wrong, I would like to say what I think is actually happening.
Andy
