DonJohnson
Hi,
I've been left the task of finishing a rotating bookcase by a good friend who recently died rather suddenly. I have made one previously similar to an earlier version he made:
so I can cope with most of the task. However, just before he died, he showed me a sketch of how he intended to finish the 18 x 18 inch top.
I have fiddled with this in Sketchup to produce a design which I think I can manage - he was a very skilled woodworker but I am a relative newcomer to joinery rather than carpentry.
The larger strips are 3 x 1.5 x .125 inch light oak (so nice grain lines) and I am thinking of using .75 inch end-grain mahogany for the small squares - which will match the mahogany vertical side strips and top and bottom mouldings to be used on this version, which has light oak shelves and central column.
Obviously the layout cannot be done by making strips as with a chess board, so the glue-up is giving me some pause for thought.
Like the shelves, I will be using a square of oak-veneered mdf for the top, and glueing the strips to its top surface.
I realise I'm going to have to be pretty accurate with squareness and sizes, but it would be nice if I could just place each piece down and have it stay put after a few seconds adjustment. Clamping for one - or more - pieces would be time consuming, and I'm sure something would move in the process.
I looked at various posts about glues, and like the fast PVAs, but wonder about the advantages of the pull-down of hide glue.
As I've recently joined this group, I thought that I might use the collected experience of members to get some hints and suggestions before I embark on this 'sticky' problem. :roll:
Your comments would be welcome
Don
Don
