Good day
The title is glass table but, actually, I'm just changing the top according to the last order of SWMBO (ok, I also love to do it)...
I built the table some 8 years ago while living in Japan.
It's made of Luan, 600x600mm and stained 5 years later.
The top (frame) is Oak, 30mm thick, 100mm wide and 620x620mm, I'm using the same stain and hope that it will fit somehow to the stained Laun.
Now, I'm painting the frame but, because of the weather the drying time between the layers is very long (so was the gluing and staining).
The design is that a plywood will sit inside the frame, and on top of the plywood, 6mm glass.
Between the glass and the plywood will come "something" that I cannot tell you (by order) and you shall have to wait and see the finished top.
Regards
niki
Regards
niki
