I stumbled on the following idea at the weekend and it worked well, so I thought I'd offer it for consideration here.
I have a piece of glass measuring about 2' x 1' x 1/2" which generally gets used as a surface on which to do glue ups as glue is so easy to wipe from it. I'm currently making a small box of about 1' long in order to store lesser used chisels. I'd planed all four sides and then squared off all the edges and was sure that everything was bang on. As luck would have it, the glass was on the bench and so I stood the pieces on it prior to glue up as part of a last check. It was immediately obvious that one end piece was leaning about 1° - 2° out of vertical. That had not been apparent during previous checks on the bench top (poss due to tiny crumbs of wood being there?) and I'd either not checked that side or had missed the error with my square. As a result of the relevant correction with the block plane followed by a second quality control check on the glass the box fitted together absolutely bang on.
So the bottom line is that in future the final quality control check for components which need it will be done on the piece of glass and with the combination square. I mention this in case anybody might find it to be of use.
