So I need a few shop vac hose adapter making and getting them 3D printed seems the perfect solution.
Any recommendations on UK based 3D printing services?
Pleased to hear it worked for you DougHave you seen @Myfordman solution for hose adapters, I used it recently, very clever
http://www.thewoodhaven2.co.uk/viewtopic.php?f=20&t=5523
No I haven't, going to take a look seeHave you seen @Myfordman solution for hose adapters, I used it recently, very clever
I always used to make up adaptors and things with what I had sitting around. Since I’ve had the printer I’ve found it’s often much easier to print something. A simple size changing adaptor for a vacuum is a minutes work in the CAD package and then another minute to set the printer going. I then just leave it to do it’s thing and an hour or two later I’ve got my part.The place that in Aberdeen that dickm refers to above sounds a lot like the Men's Sheds that seem to be popping up all over the place in UK (though originally an Australian idea I think). None here unfortunately, but they do have a general website (you'll have to Google, sorry) showing the various UK locations. From what I've read at least some of those places have 3D printers. You may be lucky and find one nearby, worth a try I guess.
But while I wouldn't in any way decry a "need" for a 3D printer (the results I see posted on here often do look really good) there ARE plenty of other ways of simply and cheaply making hose connector adaptors:
1. Myford Man's method as linked above (I hadn't seen that one before, so thanks to whoever posted it first);
2. If the diameter differences aren't too great, then various off cuts of "plastic" waste pipe, kitchen overflows, etc, etc, plus a hot air gun have worked well for me in the past (not my own idea, there are numerous YouTube "how-tos" out there);
3. If a big diameter difference, I've had great success with odd off cuts of thick ply (if necessary, 2 or more bits glued together), plus hole saw/s, spade bit/s, Forstner bit/s, plus ideally a scroll saw, or if not then a band saw with a narrow blade (or if neither, then a simple hand-held jigsaw/fret saw/coping saw).
Easy peasy, even if (sometimes) a little time-consuming, AND I'd guess both quicker and cheaper than getting a 3D print. And MUCH better than just sticky tape and/or Jubilee clips!
HTH
I did try 3dhub and was quoted one £100Hi Britman, my printer went t*ts up in 2020 and I just haven't had the time to sort it in the last many many months.
I needed 25 parts and used 3dhubs last month - I think their business model is they outsource to whoever can print - not sure if they are UK based either?
You can get quotes online - do you have an stl or similar? Upload it and it quotes. Maybe worth a look if you haven't already.
Can't say if they are the cheapest due to surcharge or viable for small quantities, but my parts were delivered on time which was crucial - I provided the stl & got them - to me that worked
Cheers,
Nick
Yup, need to get my printer going again as I had fun making other things too
I quite often make parts that simply wouldn’t be straight forward without a printer. I did some work on my landrover last week and needed some covers for the grab handle screws and a replacement trim piece for the seat belt. I drew Both in CAD and printed the parts. The drawing was about 30 minutes in total. The printing took some time as I printed in fine detail and use a 0.2mm novel for the very thin grab handle covers.
View attachment 107439View attachment 107442
Dan made me 5 adaptors at £5 each with free postage.Dan goodier
Yup- practically every town here in Oz has a 'Men's shed' (although many have women members too lol)- a great idea thats taken off hugely here with the aging 'baby boomers' who often downsize their properties to a smaller place- but find their 'shed' collection is simply too big for the new place...The place that in Aberdeen that dickm refers to above sounds a lot like the Men's Sheds that seem to be popping up all over the place in UK (though originally an Australian idea I think). None here unfortunately, but they do have a general website (you'll have to Google, sorry) showing the various UK locations. From what I've read at least some of those places have 3D printers. You may be lucky and find one nearby, worth a try I guess.
