Hi all,
I'm interested in starting segmented wood turning making bowls and vases, etc.
But... having watched YouTube, it seems that drumsanders are "essential" to flatten the segmented layers/rings once glued together. Then the layers or rings seem to be glued together to form the piece in a batch - and then turned.
The other option seems to be, once a ring is glued to the base block (which is attached to the chuck), to face off one side as true as possible on the chuck, then using a straight block with sand paper to sand true.
Are these the only options to perform segmented wood turning?
Should I invest in a drum sander? And if so, any advice?
Thanks,
Lamb
Thanks,
Lamb
