I am fairly new to jointing but I am having a slight issue. When I run by boards through, and then put them next to each other they tend to be perfect on the ends and then a slight gap in the center (Maybe the thickness of a fingernail)
Between a hand planer and a sander I can usually get it near perfect but it takes loads of time.
Should I be getting perfect edges with just the power jointer?
If so, what is the most likely issue with my technique?
Thanks!!
Thanks!!
