Garage floor paint / garage makeover!
HeliGav
12 May 2013
Staffordshire
I have a double garage which im using as my workshop at present, the garage floor in concrete and solid but dusty. Can anyone recommend something to paint it with. Want something simple, hoover dust and one coat, any ideas, make where I can buy. Has anyone experience? Thanks
The concrete floor was laid too wet and when it was " tamped" the water brought the sand to the surface. The sandy finish needs to be stabelised as any paint will only stick to the sandy surface and can keep lifting.
Sweep the floor area, or half if that's all you can clear. Mix Unibond, in the red can (exterior,and frostproof) at a 1/3rd unibond to 2/3rds water mix it well in a bucket and brush well onto the floor with a soft sweeping broom.
This will soak into the concrete like a primer, and seal the floor. you may need a second coat
I would use it like this for a few weeks and see if you need to paint it.
Don't put the unibond on too thick a mix, it must soak in Regards Rodders
