Garage doors, having a go myself!
johnsbegood
New member
2 Aug 2014
Worcester
Hi guys and girls.
I'm thinking of making some garage doors out of wood. I've been on google looking for inspiration and styles. i think i've whittled it down to a simple wood chassis and then face it up with some simple tongue and groove. there will be a center support along with one at the top and bottom so there's something strong to screw the gate hinges into!
i thought id ask for some of your advice and ideas. The door doesn't have to be amazingly secure like 10" thick etc but a simple 4" would do.
is there any online plans i could follow?
i've some simple wood working tools like compound double mitre saw and a palm router, plus the usual saws, drills, set squares etc.
i could buy some doors but the ones i can find are a lot of money and id quite like to have a go myself. in total there would be 2 barn type doors that would fill a double garage aperture.
Paul
Garage doors are not intrinsically difficult, but they are large and if you really do want them 4" thick they are going to be heavy. Heavy means a lot of strain on the joints, especially on the hinge edge.
If you want quick and dirty, have a look at the posts following here:
post935794.html#p935794
They are dominoed, but you could use more trad M&T joints. But note that even these, with sheet OSB screwed and glued over the skeleton, have dropped a bit. The forces on such a door are huge, which is why you see so many old droopy garage doors.
Thanks guys! i said 4" without really thinking. opps. but something like these:
ebay item number: 191204521580
not sure if i'll get told off for posting that link so apologies in advance.
i couldnt find that link blackrodd?
The support i'm thinking of doing is a big timber either side screwed into solid brick then use 3 gate hinges about 18-24" screwed into that timber and then onto the door itself.
should i do a certain joint in the corners of the timber or just screw some long screw into it?
Sorry about the free plans link, now back on the first reply.
Found you're prefered doors, from the dreaded fleabay, link below.
I would suggest you find out what the door makers suggested, or recommended hinge type and arrangement is.
I didn't see the makers frame made or recommended for this set of doors, you ought to check that out too!
That's a cheap old price, at £245. I would have liked to see a bit thicker t&g than 14mm finish, but one thing to remember is that bigger and chunky is more weight and can be a little self defeating, more weight, and more weight, etc
The materials and sizes are down the page on you're fleabay door page so you can make up a cutting list For you to price up materials, etc. if you are keen to make this yourself.
Regards Rodders
http://www.ebay.co.uk/itm/191204521580? ... 26_rdc%3D1
This is my first attempt at a set of doors, I chose a mortice and tenon construction with glazing to add some light: https://www.ukworkshop.co.uk/forums/double-workshop-doors-t88458.html. I never got around to adding the rest of the photos to that post, I'll try and get around to that this week. I would personally question the need to go to 4" thick rails and stiles, mine are about 44mm and even front doors designed for security with a double glazing unit in are only around 60mm thick. 2.5" would be a sensible upper limit in my view.
I would suggest a wood like Western Red Cedar which is both resistant to rot and nice and light; as others have pointed out the self-weight of a large garage door places a lot of stress on the joints so anything you can do to make it lighter (and more manageable to build and install!) is a good decision.
