Fuzzy patches on dining table top
John15
27 Jun 2013
Near Oxford
My recently completed oak dining table has developed fuzzy patches (like a two day beard) on the table top. The apron and legs are OK. The table was given 3 coats of Leiberon Finishing Oil and two coats of clear Black Bison Wax.
I would be grateful for any onfo as to what is causing this and what remedial action I need to take to correct it.
I suspect water has got in there somehow which has caused the grain to raise. Likely causes are wet cups or glasses, or it could have been something like warm serving dishes of food. Additional coats of the finishing oil might have proved more resistant to water ingress.
I'm not familiar with Liberon's product, and the product description at their website is pretty opaque. All they say is the product is a blend of (unspecified) "high quality oils", and the MSDS lists a number of solvents. I can't advise you from personal experience how good this stuff is in the challenging situations Liberon discuss, e.g., kitchen worktops and tables, etc. All I can say is that I've never found an oil only wood finish that creates much of a barrier to water and other liquids, unless many coats are applied, i.e., 10, 15, or more, but Liberon's stuff may be fine with just two or three coats. Maybe other posters have used it and comment from their experience.
Anyway, I suggest you use some white spirit, a nylon scouring pad and paper towels or clean cloths to remove the wax, and leave the surface to dry throughly. Then, if the fuzziness is still there, rub down the whole surface gently with some fairly fine abrasive paper (220 - 320 grit) making sure you smooth the fuzzy bits, and apply at least two or three more coats of the oil. Slainte.
Be very careful applying to many coats of oil based finish as it will end up like a lacquer or varnish. Remember oil finish is a very poor heat resistant finish just like wax I agree the fuzzy patches are raised grain due to some sort of moisture getting into the wood
