Philw
Hi all,
1. Looking to build simple shelving within my airing cupboard and built in wardrobe out of plyboard. My research has turned up Birch plywood BB/BB is the best looking stuff for the job but ever so expensive at £100+ per sheet.
I've spoken to a local yard who have similar but I think its only BB one side and far more reasonably priced at £45 or so per sheet but none in stock for the foreseeable.
Any recommendations on what I could go with - should I hold out for the above to be restocked?
2. How do you recommend fixing the freestanding shelves? I am assuming simple battens fixed to the wall to rest the shelves on? Any alternate recommendations?
3. The largest shelf I will make is ~750mm x 650mm. In your experience will a single sheet of 18mm ply withhold most weight or should I brace it?
4. I've seen the key to a prime edge finish is careful planning to remove all saw marks then a sand from 120-240grit. Any further comments?
5. If anyone in the east midlands/nottinghamshire area has recommendations on a good timber yard also, it would be appreciated.
