• If you have bought, sold or gained information from our Classifieds, please donate to UK Workshop and give back.
    You can become a Supporting Member or just click here to donate.
FS: Metabo ADH 260 Magnum p/t
LJM
27 Aug 2012
Cheshire
Metabo ADH 260 Magnum p/t in very good working condition, lightly usd and well looked after.
Metabo billed it as "simple, rubust and accurate"
Long planing tables (1200mm) suitable for planing of long workpieces.
Large capacity throat (165mm x 260mm), cast iron table is supported on four acme threaded spindles securely running on bearings. The long tables help to avoid tilting of long workpieces.
Fence tilts steplessly from 45 to 90 degrees. Rigidly supported at either end to avoid flexing the fence provides excellent results everytime.
Easy adjustment of the chip thickness from 0 to 3mm.
260mm by 60mm cutter block with sample effective fine adjustment.
Comes with 2 sets of resharpenable knives (one set unused).
Not pictured are the guard and the extraction hood; both are included in the sale.
Throat: 165mm
Max cutting width: 260mm
Cutterblock diameter: 60mm
No of cutters: 2
Max depth of cut: 3mm
RPM: 6000rpm
Wood feed rate: 5 metres/min
Gross weight: 80kg
Length of thicknessing table: 500mm
Length of planing table: 1200mm
Motor Capacity: 1850watts
Voltage: 240v
The machine is in north Wales, near Wrexham. However, I regularly travel around the UK, so could potentially deliver or meet somewhere.
£395
    76.7 KB
    102.1 KB
Anyone used this machine?
What's it like?
Better than the smaller 260 machines?
Many thanks
James
Sorry I thought it would be well and truly gone just wanted opinions on it...as have seen one for sale...
Cheers James
