Hi,
Many thanks scrimper for adding your interesting video. It sure takes me back to the time many dads where interested in hobbies; it seemed like every household had hobbies manuals kicking around; I must have been about 7 when I had my first go at fretwork in 1954. I've owned the expensive Hegner scroll saw but didn't often use it so sold it on; I bought it second hand and didn't lose money on it. I've owned both fret and coping saws for a lifetime but never seen the lever operated fret saw you demonstrate.
Just for interest I think the last time I used my fretsaw on a decent project was when I dreamt up the idea of making my own brass nameplates using the fretsaw with piercing saw blades which cut metal.
Kind regards, Colin.
I was heavily involved with vintage valve radio restorations as an hobby; one project I did was to restore an AVO WAVE WINDER and this needed new change gears so I made the gears and also a wooden box to house them in; these gears tend to get lost over the years so I wanted a way to identify them hence the brass nameplate. Above is a picture of the completed nameplate; I cut every letter out using the fret saw then super glued each in turn to the brass sheet backing adding an authentic brass border.
Here's a similar nameplate made for a chum using the same technique.
The finished nameplate; I also made the wooden box.
(*******This is inside the box; a full set of cast iron change gears; I was honoured with a top restoration award for this project; I also dreamt up a new way of indexing on the lathe for the gear cutting but it's too long and complicated to add and I don't want to bore anyone.*******) What a shame these days when few dads will even know what a fretsaw is being more interested in kicking a ball around but times move on.
