Do you mean 'tails'?These are the bottom of the rails not the top which has stumped me!
A pair of these is what you need....
I think you may have missed the part of his post that says: "the connectors are 3/8" threaded but they have a brass collar in front of the thread which prevents you fitting a thread on them". I have emboldened the most salient part to attract your attention. He also posted a photo of the item showing in pixels what he originally stated in letters.
I know I'd run two pipes up a 4x2" to a pair of outside Taps but the Mrs and the girls might object!James the flow rate must be quite low through 3/8 as the bore must be 1/4 ish you must have to start running the bath on Saturday for a Sunday dip . I know combi presures are low but thats a funny size for a bath
Sorry read it wrong ignore me had a funny day and a covid *** ( well thats my excuse)
These are the opposite way round. The threaded end is where you would expect push pits or compression fittings!Ive not seen the ones with the bit of brass before. Im more familiar with these -
They dont cost much, so it may be just as easy to get new tails?
Be aware that they come with all sorts of different threads on the end, and are often a pain to do up once the tap is in situ.
These are marked red and blue - red for hot and blue for cold , they are tails for a mono block tap but they look quite large -always best to buy the tap complete and you know they will fit -
