paulm
IG paulm_outdoors
Just had a look Geoff, it's listed on the programme guide but looks like no content until 7pm if i'm understanding it correctly, so can't absolutely confirm at the moment. Will try and remember to have another look later !Geoff_S":3bwlqgab said:paulm":3bwlqgab said:Yep, unplugged sky plus box and plugged in the humax freesat box to the same satellite dish cables, and worked straight away, no issuesGeoff_S":3bwlqgab said:paulm said:New humax box arrived yesterday, decided to swap out the sky hd box straight away even though there's a couple of weeks of the notice period and usage still left (given how little we watch sky stuff anyway).
A doddle to set up, and the answer to my own original question, yes, the new freesat box picks up all the bbc channels too that the sky box wasnt, so job done and no satellite messing required !
The picture quality on freesat looks better to me also, always felt that sky pictures were a little less sharp, don't know if their box degrades the pictures/signal for some reason? Not drastic, but noticable....
Sent from my SM-A530F using Tapatalk
Just to be clear, you had a Sky dish and just plugged this into the Humax box, set it up and it worked?
Wow, if that's all it is, I'm off to buy a Humax box! Which model did you get?
There's only a couple of versions on amazon, the 500gb capacity one we got that was about 170pds and the 1tb capacity for a bit more. Can't get the specifics at the moment, nut just make sure you get a humax freesat box and not a humax freeview box, tjey do both versions the former being for use with satellites and dishes and the latter being for use with arials.
Thanks Paul
It's the aerial reception that I am having the problem with. For instance and the most obvious problem is that BBC 4 in HD either will not load or disappears completely off of the list! And I am sure other channels are dropping off. Maybe being able to use my old Sky dish will solve this? So are you able to see BBC4 in HD on your Humax box?
