G S Haydon
- Joined
- 24 Apr 2013
- Messages
- 1,667
- Reaction score
- 223
Same brief as the "Free Try Plane" thread. https://pinie.cz/en/our-products/jack-plane-classic
What's different about the Jack I have is the length, it's 220mm instead of the website stated 240mm. Dlivery would be £4.00
Do note on this one, there is a dent on the sole on this plane. I hot Iron would help lift it, but if you are using it as a Jack plane is supposed be used (rough stock removal) this dent should be no problem. Also the horn at the front is loose and falls out. If it was me, I would glue and screw it into place, but I'll leave it to whomever wants to take a punt on it.
The plane has not been used and would require setting up to suit the new owner.
