Alexam
Bandsaw Boxmaker
I need a 55mm Forstner bit for an insert, (don not wasnt a hole, just insert) does anyone have any guidance on reasonable quality bit please?
Malcolm
Malcolm
lurker":2npv4zhr said:Thats on the big side for a forstner
Have you considered a hole saw or a tank cutter ?
A tank cutter (assuming the hole is not too deep) is quite versatile as you can fit custom ground blades.
sunnybob":olqet4dg said:"From the Bay I bought a Silverline 2 inch Forstener bit which was not good :roll:
They replaced it with a similar below par bit, it put me off Silverline somewhat"
Oh man, thats a brand word that should be used in the same sentence as "bought"
sunnybob":20gy4n72 said:ARRGGGHHH! I missed out the "NOT" word.
Edited now though.
twodoctors":ho10j3oo said:http://www.screwfix.com/p/wood-drill-bit-set-35-pc/75037?_requestid=93995
I bought these and they are good (enough) for an amateur like me. Biggest is 54mm also.
