Hi all i'm a newbie to the wood working world and a newbie to UK Workshop forum.
I have a problem guy's i'm having issues trying to drill/bore holes using various size Forstner bits anything from 15 mm to 4 inches in diameter. I've tried nearly everything to get the Forstner bits to work but i can't see why there not working right for me. I've tried turning the speeds down on my pillar drill to 300 but i'm finding the drill stops spinning and doesn't even cut when i make contact with the wood cause its on a really low speed. so i try to speed the pillar drill up slightly to see if it helps the drill to make a cut with the Forstner bits but they either struggle to make a cut or just catch in the wood again stopping the drill chuck from rotating. I've also made sure that the Forstner bits are still sharp and not blunt. I've tried them on various woods soft and hard but not much luck, i'm loosing a little faith with them now and two of them are quite expensive to buy to not use anymore.
Any help would be greatly appreciated guys thank you
