AJB Temple
Finely figured
The reason I got the lathe (second hand immaculate Record CL1, with extra turning rest and a few other bits) was to turn spindles for furniture work, and I am fine with that. However, I would like to have a go at turning bowls, as I already have a lot of free blanks that just need a bit of action on my bandsaw before they are ready for use. However I have no chuck.
Having had a search here, and watched quite a lot of you tube videos (e.g. Richard Raffan's [to me] excellent videos on basic bowl turning) I have ended up quite confused about what I need for a chuck. He seems to use three different ones, starting with a basic screw thread and then two more complex ones to grip the inside and outside of the bowls. He commented that they do not mark the wood. When I was at school (some while ago....) I am pretty sure that for the one and only bowl I made it was screwed to a plate which had a spigot on it to go in a chuck.
Please can you tell me what I should look out for as a chuck suitable for making quite simple bowls up to say 12" diameter (but starting with small stuff) on the CL1? It has a rotating headstock and a special tool rest for bowls. Speed control is via a pulley system, not electronic. As this is just a bit of a sideline activity, I would prefer a reasonably economical solution and am in no rush, so can scan eBay. You can assume that I am a complete ignoramus.
Thanks, Adrian
Thanks, Adrian
