Footswitch for Hegner Scroll saw
Roughcut
28 Aug 2012
Norfolk
I have an old Hegner Multicut 2 Scroll saw, which is similar to the newer version Multicut 1.
I am looking to add a footswitch for more convenience.
I emailed Technology Supplies yesterday to ask them if the Hegner footswitch they sell is compatible with the scroll saw I have without needing to modify the saw or mess around with electrics.
But I have not yet received a reply. :roll:
Are there any other types of footswitch available?
I bought one of these, as did another user of this forum, and with a substantial saving over the Hegner switch. You have to wire it yourself, but it's easily done. You do have to wait a week for it to arrive from the far east, but the dealer is reliable. The microswitch went faulty on mine so they sent me a complete new footswitch and told me to keep the old one, so I would definitely recommend them.
How would you wire one in? Would it be the flex running to the plug, remove that, wire to switch and run plug from the switch itself?
Leave the plug on the saw, that way you can remove the footswitch and still use it without. Fit flex with 13a plug coming into the footswitch and flex with either 13a socket or 'kettle' type socket going out. Switch the saw on and leave it switched on as it's now switched by the footswitch.
Just ordered mine
Also looking to use it with the Aldi equivalent of the dremel in addition to the scroll saw
Thanks Martin
Brian
I ordered mine on Thursday and it arrived today! :D
I will see if I get time to try and wire it up tomorrow.
I also got one of these foot switches about 3 years ago and wired it as you have described with a 13 amp socket and use it frequently with various power tools. No problems with it whatsoever.
Vic
martinka":381halxi said:
Just wondering, why would you want a footswitch for one of those?
I have a flexible drive on the 'dremel' and use it at times for power carving ie with carving burrs etc. It would make it easier to stop and start the carving burr rather than reach up and turn the dremel off much like a Foredom Power carver see http://www.youtube.com/watch?v=wxAP1pfCLo0
Foredom's are much better than a dremel, but the dremel works for me as I don't do too much carving.
Brian
Brian
That makes sense. I don't have a flexible drive, though it's on my list, so I didn't think of that.
martinka":1sa7gcad said:
I'd forgotten it was Phil who found that switch originally. Not seen him in here for a while but it looks like he's moved to turning.
Still here Martin! Lurk occasionally but circumstances mean I just don't have time to get in the shed or contribute.
I am now back at work full time after a year of sickness and my wife had an op the day before my 50th in Jan which has left her immobile and will continue to do so for another 5-6 weeks. This has left me rather busy running the house, taking care of her and the kids (and the dogs!) and working. The lathe was my birthday prezzy but haven't been able to use it for more than a few hours. - just don't have the time or energy. Things should be back to normal by mid to end of may and I can't wait to get back on my saw and start contributing again. It keeps me Sane!
Wired my footswitch up this afternoon and seems to work as I wanted it to. :)
I purchased a 13 amp 10 metre trailing single socket extension from Toolstation (£10.98) which I cut in half so I have 5 metres of cable which is plenty.
I also purchased one of those led socket testers (£7.10) which I used to check that polarity and earth were correct.
I would add that although the footswitch is sturdy, the manufacturer has cut corners on making sure everything is insulated correctly.
So I added some rubber where the switch is and removed the paper that was there from the factory. :roll:
Heh, I'd forgotten about their 'insulation'. I lined the inside of my footswitch with some 3mm rubber sheet that I had lying around. Good to hear you got it working OK.
I don't know if it will matter to you, but I found the spring a bit too strong and when I relaxed the switch would gradually rise until it switched off. First off I shortened the spring, but eventually I fitted a weaker spring so that the weight of my foot was enough to keep the switch down. Bigger feet than my petite ones might not have that problem. :wink:
Foot switch arrived, now wired and working.
Like others not happy with the paper insulation, although I suspect it is OK just looks naff.
My additional solution was to add a piece of plastic between the body and the micro switch support. If you do this you need to adjust the micro switch striker plate because you have raised the switch and there will be insufficient movement to operate the switch. It's a soft metal plate so it bends easily. Also taped the terminal blocks connecting the earth and neutral wires.
Can't see a CE mark on the foot switch - is this legal? I suspect it is not. Which raises the question of why Amazon are selling it - knowing Amazon they will have some smart answer ( that may or may not be correct).
Brian
