Foot Peddle
Waka , I can't give a definitive answer to your question as I don't have a lot of experience .Scrollers in US seem to think they are . I asked the question here and from the response it seems that while they are not essential they are a very useful thing to have .I'm sure some of the experienced scrollors will be along and give their view.
hi waka
i have the foot peddle fitting to my delta and i wouldn't be without it, i must admit its not a necessity to be able to scroll, but i love the luxury of it.
Like Steve I would not be without my foot pedals, they are so convenient and scrolling is a much better experience. Once you have used one you wont want to use a scroll saw without one.
OK, I give in where do I get one ,???? Is this slope as steep as woodturning he ask's .I was looking at the different makes of saws the top scrollers use and have concluded that the Hegner. Multicut 1 with V/S is as much as I can handle , (I think) :eek: :lol: :lol: :roll:
Variable speed, foot controlled;
BugBear
BugBear
Do you still make pieces with the machine .?? One thing that stands out for me is the stand with its three legs a classic. Thanks for showing.
Thanks for the info guys, I've found that when I take one hand off the wood to switch the machine off, it has a habit of slight movement.
So I thinks its the foot switch for me.
Hi Waka ,
The reason i like mi foot switch is that i dont have to take my hands off the job , simple as that ,
I made mine with electrics from Maplins , they have two kinds of switch , either switch on and then off , or
a none latching type that is on wen you press it and of when you take your foot of , that my type works fine .
The problem comes if your saw is fitted with a nvr switch , you will need to re wire it . #-o
But i think you will find it well worthwhile :lol:
-----------------------------------Frank----------------------------
Hi Philip ,
The short answer to the sewing machine switch is no ,------------- to do with the electronics,------------ :( :(
Could perhaps, use the actual mechanics of the plastic bit , but not the 'electonicery' bits !!!! as most sewing switches control the motor speed
and that wont work on your saw . it needs to be just an on /off switch---------------Frank---------------
scroller frank":18x2x45c said:
Hi Waka ,
Thanks for the info Frank, I think I'll just ask Santa to bring me one. I wouldn't feel confident about making my own.
I think Santa will be having requests for all sorts of goodys , :wink: just hope he gets both yours and mine right !! :ho2 :deer
all the best ----------------------Frank--------------------
Just in case Santa is busy or has run out of them :lol: Where would one find one, and what should I look out for as regards 'electric's I am on 240 v .
Thanks in advance.
