Flexy hose for extractor
The Bear
10 Sep 2007
Surrey
Can anyone recommend where to buy flexable hose about 40mm diameter to use to connect up to a shop vac. Don't need much, 1.5m will be more than enough. Also rigid connectors, same size, need a 90 degree bend and a Y piece and a short straight piece. I think the rigid pieces can be got as standard sink waste pipe, but what about the flexy stuff?
Mark
Go to your local aquatics supplier, if it stocks a decent amount of pond gear it will have just what you need as 40mm is a standard filter waste size. Where i work 2m of standard viniflex would cost you about a fiver, six quid maybe, add two pounds for the heavy duty gear (i would recommend this as its a lot better). hope this helps
