Fixing a coffee table top
John15
27 Jun 2013
Near Oxford
I have made a 700mm x 400mm oak coffee table with just fixing the top still to do.
Am I correct to assume there will be minimal movement of the 18mm thick top in a consistent environment of a centrally heated house, and if so would screwing it to the rails using a Kreg pocket hole jig be OK?
Regards,
Any reason not to use buttons in the normal way? If the frame is already built then a biscuit jointer on a couple of vertical settings can be used to cut slots wide enough for buttons.
Buttons are obviously the considered, conventional choice that allow for movement but stop cupping, but the chances are you'll be fine with pocket hole screws for that size of top. If it's for yourself, I'd do it that way and learn one way or the other!!!!!! There is a bit of movement in a pocket hole fitting. I've come across plenty of tops that have been fitted that way over the years, and have survived.
Thanks for the above advice guys. I was favouring pocket hole screws as it seemed the easiest method. But I want to do it 'properly' so I guess I should go with buttons.
My Laptop is sitting on a table, that is constructed with Kreg joints throughout; no glue either. No movement at all, in the last six weeks. I'll keep an eye on it; but I wouldn't sell the table without changing to buttons for the top.
Maybe I should add, this small table was made in a hurry to fulfill a need. Until SWMBO can sit at the dining table again, we are eating 'informally', and dining from a tray on my lap isn't the way for me. :(
