pgrbff
None of my rasps have handles, or files for that matter.
How were they secured in a wood handle traditionally?
that's why I want to fit handles, I keep seeing the same thing saidRun the tang of a file into your palm and you'll ensure all future files have handles. Damhikt.
these have a 2.5mm holeAFAIK a tapered hole drilled in the handle before it was turned, ferrule fitted after turning then the tang of the file/rasp tapped in. That's how I've done it in the past and the handles are all still on
You could open it out with something like this:these have a 2.5mm hole
In the past they were fitted with Sulphur.
Drill a hole 2/3 of the depth of the tang length, with the diameter of the tang at 2/3 of the length.
Heat the tang to a dull red and force the tang into the handle.
Repeat until handle is fitted fully.
Remove the tool. Fill the hole with powder Sulphur, heat the tang to a dull red. Push the tang into the sulphur filled hole
Allow to cool and away you go.
A saw set being fitted.
Too hot.
Just nice for the final fit.
Agreed. In the case of a drawknife or something where the handle needs to be pulled against, I've most often found the tang continues through the handle and a washer is added and then the tang peened over to hold it securely in place. I'm just replacing some drawknife handles at the moment and have had to grind off the peening to get them off.When you use a file or rasp, you are pushing the tool, so you are always forcing the handle onto the file body.
It will thus need a lot less secure fixing than something like a drawknife where the normal mode of use is pulling the handles off the tool.
There is nothing different for a file or rasp than would be used for a chisel.
A cheapskate version or an option if you have more files than handles is to use a golf ball.
I always cringe whenever I see some 'silly' person using one w/out a handle. There's plenty out there on YT, especially model railroad ones.Run the tang of a file into your palm and you'll ensure all future files have handles. Damhikt.
That is - IF you have golf balls - my guess is handles are cheaper than golf balls, unless you go 'dog walking' at night on the golf pitch!When you use a file or rasp, you are pushing the tool, so you are always forcing the handle onto the file body.
Interesting - tell us about the properties of the sulphur when cold - adhesion, gap-filling, strength etc.
Molten sulphur was poured into the sockets when fixing iron railings on top of walls.
