The Shark
Hi Guys,
Having finally gained access to a camera, here are some shots of my first turnings. I know none of them are technically very difficult, but as a novice I'm quite pleased. All turned on a Myford ML8.
Priest made from cherry. I drilled a 10mm hole down the length of the business end, filled with lead to add some weight, and plugged.
Bud vase made from cherry. The one on the right is a brass one I made at school 30years ago. The one on the left is an attempt at a copy, which give or take a mm or two is nearly there!!
Bottle Holder in yew.Turned on a faceplate.
Pencil Holder in Walnut. Turned on a faceplate. Tried to incorporate the defect into the design. I think it works, but would be interested in any comments.
Yew Goblet. Can't take all the credit for this one, had a bit of help at woodturning club, but thought I'd show you anyway.
Any comments greatfully received.
Malc
Malc
