Nippychippy
My first bowl loved making it only popped out once scary and the fail bit
Is I took to much out of the wall but I know next time so much to learn
KimG":4fe64pai said:Bit of a litany of errors there NC, if you got a dig in with a scraper you must have had it at the wrong angle, a scraper should always be slightly in trail, that is the cutting end should be lower than the handle end and the tool rest should be slightly above the centre of the work, that way you wont get a catch.
Nippychippy":wzm75mls said:....... after that I tried using the jaw chuck and my skew
Chisel nicked the chuck and wreck it so that's what's put me off but I will get back to it.......
