capocobono
I have a couple of questions about making some inset cabinet doors. I'm sure it's relatively simple but I've never done this before and I'm struggling to find exactly what I'm after online.
First question - if I'm making a simple cabinet using 18mm ply with two inset doors and a centre divider how much of an allowance gap should I give around the door and the frame. I measured my kitchen cabinets, they seem to have about 0.25cm all around. Does that sound about right? I also wasn't sure if I should leave a little gap between the door and the inside shelf? I was thinking about 0.3cm since I'm going to put a push to open device on the bottom of the shelf.
Second question is just more making sure I'm correct. I was going to use Blum inset hinges (3750) for this. I'll also need to buy a hinge cutter bit and some kind of cutter guide.
I've attached a diagram of what I'm making.
Hope you can help.
Hope you can help.
