thecambridgetryer
I'm just about to start on my first project of several and I'm trying to get some advise before I start and ruin a load of materials.
We are renovating a house and there are several alcoves which need built in storage. Most are going to be cupboards to hide all of our stuff but one is going to be bookshelves. I thought I would start with that one as it should be the simplest.
If I run over my plan I would appreciate any feedback.
They will be chunky split bookshelves, books on the left and firewood for the woodburner on the right.To make my life easy I'm going to use 22mm MDF with 20.5x44 mm PAR face frame, shelves for books are 22mm thick with 44mm width face frame. Shelves for wood are double thickness so they are strong and there is no overhang to catch on the face frame. I have already built boxes in the alcove base before we replaced the floor and skirting so I don't have to worry about that.
I was just going to buy a router and straight edge, rout out 22 or 44 housing joints for the shelves, glue screw the two bookshelves together, screw in to 22mm battens on the wall and then nail and glue the face frame on. Maybe scribing or caulk depending on how positive I'm feeling by that point.
I'm not entirely sure how to finish the top, I've seen some with fancy coving. I've planned it flush with the alcove as that seems right but the cupboards will probably come out further.
I'm modelling it in sketckup
