Hello, again.
I've started building the carcasses this week. I did one for the workshop as a practice run to sort out any potential problems and get a better idea of the order or working. So far it's going really well and I'm loving the combination of the Domino 500 and the Kreg K5.
I have another question for you.....
Where do i position the plinth feet? Because the base is butting up against the vertical, should the feet run right to the edge of the cabinet so that it's supporting the side panel as well? I know that I have about 5 dominos and 5 or 6 pocket screws fixing the base to the side so it should all be nicely fixed but it just seems that a lot of load would be going down through the verticals.
I'm using these feet from Hafele with the 100mm shaft.
http://www.hafele.co.uk/shop/p/kitchen- ... 37018/8021
Thanks Dave
Thanks Dave
