chaoticbob
I have some bits of 230mm wide by 27mm thick sapele which I'm hoping to reduce to 6mm boards to make a box. I have a Record 350S bandsaw, so not big enough to make a 230mm cut. So first question is: what depth of cut is realistic for a machine of this size in hardwood? I assume Record's claim (230mm actually) is exaggerated as these things usually are.
Second Q is about a suitable blade. I had the machine tuned up to cut really nicely with a 3/8"(Tuffsaws) blade but when I fitted a 3/4" 3TPI (possibly the Record one supplied with the machine, not sure) and had a test go cutting a slice off 6" pine it wandered horribly. I'm pretty sure that the problem is with the blade. I see that Tuffsaws have a new line (SuperTuff Fastcut), maybe that's what I want, but I'm a bit at sea with this so any advice would be welcome.
Robin
Robin
