Hello again
How long is this timber?
Single phase you have, but do you have 16a plugs, planning to upgrade if on 13a household?
Dust extraction at the same time?
Planning on cutting curves, or is this for processing?
I'd personally be looking for the sweet spot in size around 20"
There is no space to be saved going smaller, unless you're in a tiny workshop.
The smaller you go, the more you can't use the fence, and need use a pivot fence.
Aluminium bits whats delicate, terrible fence design, although useless anyways.
Grand for wee curves though, and quite a large table for curves.
Wouldn't do even a small tenon with it though!
Compact far Eastern machine with small table, the same footprint.
Not nice for doing tenons and dusty when you open the doors, unless you have dust extraction.
Cough splutter.
depending on your space, that could be a compact one with not much space around the wheels and smaller table like some far eastern machines,
or if wanting nice guides which don't need maintenance then this Wadkin would be the best of both worlds, footprint growing very gradually.
This Wadkin which was on ebay few years ago for 800
"Seems" a teeny bit more compact than the Italian equivalent below, of which brands there are many.
(pretty much all have nice guides the same industry standard, GL345 system.
More Italian or Italian style machines for you to look at,
The SNA(C) is the extra 40mm wheel series, so guessing a bit larger. ACM made originally.
Old Felder might have some of those, they've changed and if I'm correct, I think its only the biggest
machines larger than these, which are made in Italy.
Seems a lot of companies are making the wheels a bit larger than the standard 100mm step up.
The old SNAC are a tad rarer I suppose.
A 24" seems a good bit out of the wall by comparison, well the 20" Far Eastern machine I had anyway.
You can get these for very cheaply however,
This one required a lot, but bought for 500 euros.
I specifically sought out three phase (one with a dual voltage motor)
as I only have 13 amp household plugs.
The VFD enables one to have an easily adjustable soft start, as it's the starting inrush current
that is the strain on the supply, not running it, it uses the same juice on me auld laptop, whilst running idle.
All the best
Tom
