hi DrDerrickDrDerrick":2mv8w85j said:Finger joints look nicely done!
Droogs":1cr050m8 said:Good first try, especiall as Custard said with the woods used. Did ou use a template or freehand the letters? Also what knife blade did you use?
Curved lettering is ver hard to get right, from the images I would suggest you are holding the blade at too low an angle when going round the curves and this has caused the slight chipping. Tr to hold the blade at an angle of 60 to 80 degrees angle of attack - that is the sharp edge not the back of the blade. Appl very little pressure at all. For the first 3 or 4 strokes the blade just let the weight of the knife start the line and then apply a little more pressure each stroke after that. It takes me around 20 stokes to create a curve, let the knife do the work for you and you will get the hang of having crisp edges. Try to have the blade's outside part of the bevel at around 15 degrees as well relative to the bacground surface. This will help create a slight chamfer that aids the insertion of the infill piece.
hth
