first attempt at offset turning
peteb
1 Apr 2009
Herts
3 footed bowl.
I wasn't expecting the feet to work, so I didn't really think through the rest of it until too late. Hence the straight sides. This was originally just going to be an experiment!
It's about 6 inches across
Satisfying first try pete, fair amount of unbalanced wood to fight there.
If you turned each of those little feet on an offv
centre you have done well. Can't have been easy turning them or keeping them all the same.
Very good !
I think most would have carved the feet from a ring left on the base, looks like you have a great method that saves some carving and sanding work !
Did you do the offset work before hollowing out the bowl ?
How did you mount the work ?
Loz
yep.
For the offset feet, I used a screw chuck. I finished the base before hollowing (just a little bit of hand sanding needed)
As I said, I hadn't really thought ahead, since I didn't really expect the feet to work.
In the end I made some extended jaws for the cole chuck:
If was was going to try it again, I'd probably glue a tenon between the feet, hollow, then remove it before finishing the base.
To be honest - that might well have worked better!
The motivation for it all was really to come up with a base that won't start wobbling once the wood dries out and distorts. (esp. on eucalyptus).
Any suggestions in this regard?
