Lonsdale73
As it's almost that time again, thought I would light the blue (or maybe green and grey) touch paoer a stand back ready for the show so is the Festool Domino anything more than an expensive biscuit jointer?
I wonder if there's anyone who's got a morticer and tenoner but also found the need to warrant buying a domino aswell ?RobinBHM":2h99exqw said:You need to explain how buying a domino is saving you money, as you dont need a morticer and tenoner
ColeyS1":3ukioblf said:I wonder if there's anyone who's got a morticer and tenoner but also found the need to warrant buying a domino aswell ?
pcb1962":1k2ieh7a said:Just watch some of the youtube videos, Peter Parfitt and HalfInchShy for example, you'll see in 2 minutes why it's not just a glorified biscuit jointer
custard":kque8kd5 said:If you're a competent and experienced woodworker, capable of consistently producing furniture components that are absolutely square and straight, then a Domino will speed up your production.
No, no, no and no again
If you're a cack handed newbie who's hoping that a Domino will magically transform their rubbish efforts into something presentable, then you'll be disappointed. The Domino references off the components themselves, so unless those components are dead true then your Domino joints will be just as horrible and gappy as your current joints. So don't get a Domino to cover up faults in technique, get a Domino because you want to do the same quality work you currently produce, only a bit faster.
ColeyS1":5lrtw3ug said:I wonder if there's anyone who's got a morticer and tenoner but also found the need to warrant buying a domino aswell ?
ColeyS1":3tpuqqze said:Occasionally I need to join alot of mopstick handrails at various angles. Currently I use dowels for joining but it's a bit of a faff, I wonder if a domino would be good at speeding up that process?
