AESamuel
Hi,
This is my first post here, I just started getting into woodworking as hobby while I had the summer off uni, but I've really gotten into it and one of the things I'm really enjoying is trying out different finishes - its great to see the project uh... finished?
Anyway, I 've applied some "hycote clear acrylic gloss spray lacquer" (a car spray) to a small candle holder I've made, and the finish is nice and smooth but it does feel a little bit plasticky, so I got some "Colron refined, clear finishing wax" and some 0000 steel wool which I want to put on to make it feel a little more natural. I also intend to use the wax over danish oil finishes.
My questions are:
Should I rub the lacquer down with steel wool dry and then put the wax on with a cloth, or can I put the wax on with the steel wool to kill two birds with one stone?
How much should I be working the wax into the finish? (e.g. should I spend a minute or two rubbing the wax in, or just a few seconds)
How long should I wait after the wax has been applied before buffing to a shine? I'm aiming for the shinest finish possible with the wax.
Lastly, will one coat of wax be enough, or should I apply another? (The can says to apply a second, although doesn't stipulate how long you should wait between coats)
I hope you don't mind these beginner questions, and I'm looking forward to reading a lot more posts here on the forums.
Thanks!
My questions are:
Thanks!
