Dean":b78errnh said:
Thanks CHJ, the surface of the job is very smooth and satisfactory to the touch but despite how the pics look the best finish I can get is a satin finish. The fruit bowl in the link below was turned from the same wood and finished the same way but has a much better finish...?????
Dean
This may be down to surface speed when finishing, due to the differing diameters the surface speed of the bowl will have been much greater producing more friction.
On small items when applying cellulose sanding sealer try burnishing immediately while still moist, first with a sealer damp cloth, immediately followed by a dry cloth, this will produce a hard glossy finish which is further enhanced by the soft wax.
If you overdo the amount of sealer you will get build up streaks, ether blend these out with a drop of wet sealer or thinners or 'sand' them off with grey NyWeb (Chestnuts) or equivalent.
I personally find that after going through the grades of grit to 320 I get better results by using the the red, green & grey nywebs to finish off.
A melamine enhanced finish over cellulose sanding sealer will give you a higher gloss level, the spray versions are much easier to use than the canned versions which I found needed a considerable amount of practice to get an even, non streaky finish with.
See This thread
An increase in gloss can be gained by using a burnishing cream between coats of sealer etc.
With melamine finish I find it is best to leave the final coat at least 24hrs to cure before burnishing.
