Hello,
I'm in the processes of building my first project, two supports for a pair of loudspeakers, the design of which was posted here:
feedback-on-first-design-and-project-t97773-15.html
For the base of each support (the legs and stretchers) I want a simple natural finish. For the tops, I'm still undecided, perhaps a natural finish or painted bright glossy orange.
The wood is called "jequitibá" - it has a density of 0.78g/cm3. The wood was very well sawn when I received it. I have a Stanley no. 80 cabinet scraper that I'm using a Stanley 102 block plane that I've used to tidy any frayed edges. You'll see in the photo below that I've already started to round the edges with a block plane.
This was the first piece that I started working on and I've stopped rounding the edges because I realised it made it hard to mark the depth of the grooves that I'm cutting. I'll finish rounding them later. You'll also notice that there is a line of raised grain (is that the technical term? Or is it run out?) on the long piece towards the right. I'm encountering this on some pieces and I can't always remove them using the no. 80 scraper. Does this mean the scraper is not sharp enough? I'm using a 45 degree able on the scraper blade, no burr.
I read somewhere that cabinet scrapers work better on harder wood. I tried on a piece of ipê (and extremely heavy and hard wood) that I have at home and surface became glass-like - but on the jequitibá, these raised regions sometimes appear.
I assume I'll just need to varnish the wood. Can anyone please suggest what type of varnish I'll need to use? I think I'd like a semi-gloss finish. I imagine the wood will darken with varnishing. Correct? Will I need to sand the wood before varnishing? If so, what grade paper should I use? I like the idea of not using paper, but if I can't get rid of these ridges, I may need to.
On the tops, and if I decide to paint them, I may do this with a roller, but I think what I would really like is to lacquer the tops. I don't want to buy any spray equipment and if anyone can suggest a good online guide somewhere for non-spray techniques, please let me know. I've haven't been to a paint shops yet to ask, perhaps there are aerosol lacquer kits out there.
The second photo is of the tops.
Thanks,
Thanks,
