Finishing advice for Imbuia
Ntre25
12 Jul 2020
Reading
I have a reclaimed imbuia desk top which I am refinishing. I was considering using a couple of coats of Liberon finishing oil but would like to find out if there are other recommended finishes for this species of wood.
Presumably the desk top is no longer attached to its base, so no match is required, unless there is a base that is made of a different material or materials. If it happens that the top has an existing base in the same material and an existing finish it would normally make sense to refinish the top with the same finish as the base.
Anyway, assuming the top doesn't need to match anything else, I'd avoid a finishing oils which, as a group, tend to be a bit soft and relatively easily damaged. Imbuia is quite pale so an oil based interior varnish (short oil type) would be a tough and durable option with the characteristic of ambering or darkening the wood which helps bring out its character. Oil based varnishes have instructions for cleaning application tools (brushes, etc) with white spirits, or similar.
You could also use a water borne varnish (brush cleaning guidance is soap and water) but these can sometimes look a bit cold or lifeless and don't change the underlying wood colour as much as oil (solvent) varnish.
Personally, I'd go with the oil based interior varnish.
However, if you have spray equipment, you don't say but I guess that's not the case, that opens you up to a host of alternative finishes. Slainte.
My buddy made a waterbed from it in the eighties, still has it but with a regular mattress in it. When cut some parts were almost a yellow but all aged to a dark chestnut colour fairly soon after. He put Watco Danish oil on it and it still looks good. Not sure if the wood is the same as yours, lots of tropicals get lumped under familiar names but it is an oily wood anyway so the Danish oil worked well. Try it on the back and see how it looks and works.
I'll add that it has a spicy smell to it when worked.
