Its an enclosure for an electronic musical instrument.
My main work is cnc routing and silk screen printing, but someone asked me for the wood ends, so i did some CAD for the ends, and asked a machine to cut them...
This was the starting wood -
The end of that big crack became the black resin work on this -
Here is the rest of the job -
I do not do the cnc bending here, but the rest is my work. As in i buy in 8x4 sheets of anodised stock, CNC route it, then silk screen print it.
The cases in the middle were sprayed by me. Epoxy primer, and then a 2k top coat. And then the logo silk screened.
I had issues with the top coat - its one of the "industrial" 2k finishes, and is supposed to be matt, but it took me some messing about to get a true, uniform, matt finish, and not just a satin finish (I'm used to spraying gloss, and found the matt way harder to figure out).
But its done now.
Note, im much more of a machinist / metal worker than wood worker, and my ability with hand tools (beyond a spray gun i guess.... and im the one that anyone i know asks to plaster their house also) is limited to put it mildly.
This is my very first attempt at resin work. The job isnt perfect, as i was on the learning curve, but the job is a gift for someone anyway, who accepts the imperfections. Ive since learned from my mistakes and made these out of the same bit of wood -
(excuse the logos - i assure you that these are a specialist enough item that im really not trying to sell here!)
Thank you.
But its done now.
Thank you.
