spiderlane
Hi All,
I'm just finishing my first box project (a watch box) which is made from maple with a burr maple veneer lid. The finish is Danish Oil, which I mainly chose because it's a finish that I'm familiar with.
The box lid is starting to look very nice after 2 coats, but I was wondering whether it's possible to fill some of the pinholes in the veneer in such a way that the filler doesn't become impermeable to the oil finish? It may be that it's too late now that I've started the oiling and it looks OK as is, it would just be nice to find a way to fill in some of the holes but not have the filler stand out because the oil doesn't penetrate into it. I've used the wet sanding technique to fill the pores but of course this hasn't filled the larger holes.
The other thing you more experienced woodworkers might be able to offer a view on, is what I can only describe as "dirty" patches on the box sides in places. Initially I thought this was grime from handling during construction but during the sanding phases, they weren't removed an indeed seemed to get bigger the more I sanded back. It's difficult to show on pictures but if you look at the bottom left of the second picture you can see a slightly darker/shadow patch which is in the wood. (This was present before I applied the first coat of oil.) Any ideas as to what this is or what caused it? Or is it just a characteristic of maple? I'm new to woodworking and this is my first project using the species.
All advice and options welcome
Thanks in advance.
Mark
Thanks in advance.
Mark
