miles_hot":2h6xzi9z said:interesting that there appears to be some confusion between statements here that the bevel cut does not maintain the same position as the straight up cut and the impression gained from reading about that saw.
Can someone who actually uses the saw give a definitive view - do you have to move the rail or make some allowance when cutting a bevel cut in comparison to positioning the saw when making a normal 90 degrees cut?
Miles
About the Mafell is does maintain it's position both on a bevel and on a strait cut. But if yoy use the saw without the guiderail you need to use the "aim" in front of blade.Which is the better saw Mafell or festool? i've worked with both for a long time both are splendid to work with but in my view the mafell has a few xtra's 1 you can use both festool and mafell guiderails. 2 you can get a foldable rail. 3 You get a scoring function.4 better dustextration. 5 easyer blade change. 6 better depth indicater.6 Bevel cuts from -1 to +48.
All this being said it does not have a riving knive ? after useing it for 2years i still haven't been missing it.?
Best buy in my view the Mafell
