WoodYewToo
I would add that if you are using mains outside I would make sure you have a protective RCD on your supply to the tool. You may have this as part of your electrical installation anyway, but if you have an older system it is worth having an extension or socket with a built in RCD. Vastly improves the chances of you getting a shock.
Errr... I'm guessing that's not quite what most people are aiming for.
