I made a drum sander/thicknesser about 3-4 years ago very similar to this http://woodgears.ca/sander/plans/index.html and it has worked great, I use it for thicknessing the rings for segmented bowls and the only problem is pushing the stock through by hand on a tray, it is a bit tedious after a while, trying to keep a steady feed rate, so I was wondering if anyone who has built one of these has added feed rollers like on a planer thicknesser or a feed belt of some sort like on the Jet machines, I think feed rollers would be best as tracking belts is a problem, also getting the belt on there as it is closed in would be a problem, anyone got any views on this, or should I just go and buy a Jet 16-32
