PVA is favourite in professional workshops for two reasons,
1. 30 minutes in cramp and you can remove the cramps and either carry on with light work or just move the glued job out of the way to fully set and re-use the cramps
2. PVA gives really tight, invisible glue lines, even in the paler timbers that are currently fashionable.
The problem for the guy working on his own is that PVA has both a really short open time (much shorter than it says on the bottle, glue manufacturers are as honest about open times as car manufacturers are on fuel consumption) and it's very "grabby". If you're in a workshop with other craftsmen to hand you normally work as a team on bigger glue-ups. Plus you're really familiar with glue-up procedures, and all the cramps, bearers, cramping blocks etc will be neatly laid out ready to go.
Man in a shed however can really stuff it up with PVA. He knocks a super tight tenon half way home then moves on to the next joint, then he fumbles around getting the cramps out, then he discovers he should have taped cramp blocks onto the workpiece before hand because they won't stay put. By this time the PVA has "grabbed" and he can't get his tenons fully home, even under full cramp pressure, so there's a nasty gap at the shoulders. Next up the workpiece is out of square, but he's not really sure how he should move the cramps to correct the problem. By the time he's figured it out it's irrelevant anyway, the PVA has hardened so what's done is done.
Compare that with patient woodworker who's taken the trouble to mix up some Cascamite or uses hide glue. He can leisurely puff on his pipe and enjoy radio four, taking all the time needed to get everything square and true, with joints that are tightly drawn up.
Bottom line, always do a dry glue-up first so you've ironed out problems in advance, and only use PVA on really small simple jobs that you can complete in a jiffy.
Good luck!
