craigclavin
Good evening,
My name is Craig and I'm new to the forum. Although I've got plenty of projects under my belt, only now am I starting to develop beyond drilling, screwing and plugging skirting boards on renovation jobs..
My next project is to replace the fan light over the front door of my Victorian property. I'm out in the sticks so I assume that the Victorian style didn't make it out here until after the actual Victorian era as the house is quite Georgian (to me) in appearance. Anyway I digress, I would like to replace the very plain glass semi circle (complete with stick on lead) with a traditional georgian style fanlight.
I have a router, glazing bar bit, milescraft arc cutting kit and a drawing.
Some questions I'm hoping you can help me with. I have some oak but the boards aren't wide enough for me to get the full arc. I'd have to create it in two sections and join it, this might look a little rubbish even when painted up. Is it a crime to use soft wood for external work? There will be quite a temperature differential as one side of the fanlight is practically in my lounge, but my softwood sash windows don't seem to mind. Will I get timber wide enough and thick enough (45mm) to produce a single arc without joins?
Has anyone built one before? There is very little construction advice online that I can find, any guidance on where or how to start is appreciated.
Kind Regards
Kind Regards
