Hi all
Well started cleaning the saw down today, and as it turns out, It will need at total strip, refurb and paint.
This is due to scraping off the scale, grime and debris around the saw, It is the original paint "no overcoating" and was coming off fairly easily on the lower half off the body. However due to the cleaning program, I have expose so much bear steel which now requires a full breakdown, and paint.
I shall get the "cast top half and foot supports" shot blasted. I was looking to repaint in the original colour if this is possible, or would this have to be best match ? And following MilesH advice I think I'll avoid the Hammerite
I also ran into a problem this afternoon while dismantling the inners of the saw. firstly there are no damaged/fractured parts in the workings off the machine, worm drive looks to have many, many years life left in them. The Issue that I am having though, Is the removal of the pivoting pin from the rise and fall slide bracket and the main trunnion bracket. I've drew back the two grub screws from the underside, and tried a little persuasion with a 12mm rod and light taps with a peen hammer. The thought of using a heavier hammer send shivers up my back.
Q/ my train of thought was looking at a hub puller, or something along those lines ?
I did put some oil into the grub screw holes and replace, as well as a little around the pin,, hoping that it may permeate around the pin overnight.
Any thoughts/advice from you guys would be much appreciated.
Regards
Regards
