Wildman
I bought an Electra Beckum 1000 Extractor to use for chip/sawdust it was secondhand and collected by one relative then bought to me (175 miles) by another doing the normal Christmas run. I took it to the workshop and reassembled it today hoping for great things, boy was I disappointed the suction is really poor, it will lift sawdust if the hose is right on top of it. Otherwise not a chance. I made a reducer for the 4" hose and fitted my vax hose even that was little better. At that point I gave up and went home thoroughly peed off. The hose has seen better days but I taped up a few splits. I now wonder if someone has sucked up chunks of wood and damaged the pump vanes. I suppose the filter bag could be clogged other than that no idea. My table saw is till playing up it starts and eventually runs up to speed, then after 15 seconds or so the speed dies right back before picking up again and then running fine, only on start up. I purchased so DW40, yes DW not a typo and it was advertised as a rust inhibitor so I sprayed everything with it, guess what there is rust now on things that have not rusted before. I am beginning to get a little despondent to say the least. Then to cap it all I get home and find the 10" sanding disks I ordered turn out to be 350mm not 250mm and I have to cut the beggers down (yes I know I should read and double check and when it is metric treble check). I see everything in imperial and do not compute metric, daft I know but that is just me I cannot visualise any metric measurement but change fractions to decimals in my head in imperial no problem years of ingrained use.
