space.dandy
Hi all,
The house I've recently moved into has a newish (~2016) single-story extension. I want to fix some shelves to the inside of the external wall, but I'm a bit puzzled about the construction of the wall and therefore what fixings to use. Having taken a few measurements and drilled some small test holes, the construction seems to be ~150mm of rendered block/brick, 150mm of kingspan/celotex insulation and a layer of plasterboard on the inside. I've tapped around various places on the inside but can't hear any evidence of stud work, so I have no idea how the layers are fixed together. I do know that the extension was properly constructed and signed off, so is compliant with whatever regs were in place at the time.
Can anyone tell me what the actual construction is likely to be, and what sort of fixings would be appropriate for medium/heavy duty use?
Cheers,
Chris
Cheers,
Chris
